Results 1 to 10 of 10
    DK Veteran ghostridersa's Avatar
    Nov 2011
    Default Renault Kangoo ECU & UCH working files needed PLEASE
    Good day members of DK
    I have in my shop a kangoo 1.5 dci, 2003. The ecu and key was stolen while in a panel shop. The owner bought a matching ecu and key from a breakers yard. We have fitted it and vehicle wont start and immo light flashes all the time. We have tried immo off and all other options but still vehicle will not start and immo is active.
    I am now looking for good working files for this vehicle for the UCH and ECU which I can use on this vehicle and then make a new key and get the vehicle started. I would appreciate any help the members can give me with this vehicle. All the current vehicle info is attached hereto.
    Many thanks in advance 1.5 diesal kango
    VIN NO : VF1FCO7BF29332693
    ENG NO : D559492
    ECU DELPHI
    SEIAL EPROM (95080)
    8200498185
    8200374298
    12V= 17.03.07
    DDCR R0410C123C (81294A)
    SERIAL NO :85319174 C ?G
    BODY CONTROL UNIT /UCH
    SAGEM
    SERIAL EPROM( 93C66)
    UCH-N1-X76
    21668893-5D E V5.0 02/07/03
  2. The Following User Says Thank You to ghostridersa For This Useful Post:
    gurolelk (12th June, 2013)
  3. #2
    Elsewhere
    You need to make DDCR virgin, post 95080 dump here and will virginise for you. You also need a virgin key to write it in UCH ( you need also APV written in UCH, post here dump from 93c66 for APV ), gasoline and HIT THE ROAD !!
    Capisci, amigo ?
    Nov 2011
    Thank you Alfabit here is the complete dumps from vehicle. Please help.
    Quote Originally Posted by alfabit View Post
    Capisci, amigo ?
  5. The Following User Says Thank You to ghostridersa For This Useful Post:
  6. #4
    Elsewhere
    Quote Originally Posted by ghostridersa View Post
    PIN : BE79B51FCE8B
    Dump for DDCR
  7. The Following User Says Thank You to alfabit For This Useful Post:
  8. #5
    Nov 2011
    PIN : BE79B51FCE8B
    Virgin ecu later, i`ll edit this message
    Thank you very much, I have that pin and will await your dumps. Many, many thanks for your help.
  9. The Following User Says Thank You to ghostridersa For This Useful Post:
  10. #6
    Elsewhere
    Posted dump virgin for ecu, PIN you need for programming new key into UCH, no need to change dump, only learn new key into UCH.
  11. The Following User Says Thank You to alfabit For This Useful Post:
  12. #7
    Nov 2011
    Many thanks Alfabit I will test and let you know. Please can you help me to virgin UCH before programming key? Many thanks
  13. The Following User Says Thank You to ghostridersa For This Useful Post:
  14. #8
    Elsewhere
    No need to virginise UCH !
    You program keys - as to any other Reno car - based only on APV code, with proper tools, like Clip sonde ( old software ver < 100 ) or DDT2000.
    Or other tools, especially made for making keys, e.g. Zedbull, but never used those, for me DDT is superok key programmer.
  15. The Following User Says Thank You to alfabit For This Useful Post:
  16. #9
    Nov 2011
    Alfabit thank you very much for all your help I will try on vehicle and report. Many thanks my friend.
  17. The Following User Says Thank You to ghostridersa For This Useful Post:
  18. #10
    Elsewhere
    Ok, i want to hear good news from you, my friend.
    Good luck in your job.
  19. The Following User Says Thank You to alfabit For This Useful Post:
