Results 1 to 7 of 7
    Romania
    Default Crafter smoke after dpf removal,
    Can help me somebody to remove totally the DPF, because ecusafe don't.the car is crafter with ecu number 0281 012 539
    thanks.
    mislav88's Avatar
    Mar 2011
    DPF off manually
    Romania
    Default thanks
    Can you help me mislav88 once again.Only once again.A friend has the same error with her car.Has no error but the car still smoke.Especially when accelerate.Please forgive me that i ask again, if you can help me.thank you very much.
    The car has a 0281 013 826 bosch ecu.
    mislav88's Avatar
    Mar 2011
    here is 2nd one
    waldi1979's Avatar
    Dec 2010
    If anybody can help me in manual delaing DPF of Crafter 2.5.
    I have done it Ecusafe, but I have NOX sensor error and after drivind 1k km I have differential sensor. I can't delay it.
    Tnx
    try and report
    waldi1979's Avatar
    Dec 2010
    The problem was in difference pressure sensor. I needen't have looked for trouble in ECU.
    The sensor was chenged end everythink is OK.
    Tnx
