Page 136 of 141 FirstFirst ... 3686126131132133134135136137138139140141 LastLast
Results 2,026 to 2,040 of 2204
Hybrid View
    Apr 2014
    hi guys now tried to use my Zed Bull [Zed-Q x plus] for the first time and it is not recognizing any transponder. Has anyone come across this situation. I need to know how to solve this problem. thanks guys
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    speedy100's Avatar
    Jul 2010
    Athens
    Case study...
    What is this [Read&Write] screen exactly doing?
    For example what will it do for a Corsa C ? Will it prepare a PCF7935 to start the car (cloning) or it will need further coding via OBD ?
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
    Mar 2013
    Patagonia Argentina
    Quote Originally Posted by speedy100 View Post
    Case study...
    hi speedy, that fuction is already in effi! look for "image generator - 40 opel"
  4. The Following User Says Thank You to nicocr For This Useful Post:
    speedy100 (27th June, 2017)
    speedy100's Avatar
    Jul 2010
    Athens
    Quote Originally Posted by nicocr View Post
    hi speedy, that function is already in effi! look for "image generator - 40 opel"
    Thank You nicocr for Your reply.
    My question is about the Tab (screen) -Read & Write- in EFfi. What is the function there? Is it cloning a transponder that is ready to start the car or it will need further coding via OBD and diagnostics like OpCom etc.?
  6. #5
    Duracell2's Avatar
    Apr 2017
    Case study...
    Preparation and cloning are 2 different things.
    Preparation just writes minimum amount of data to the transponder to be validated by the car as valid transponder.
    After the registration to the car, the car writes also own data to the transponder and locks it.
    ZedBull can only clone few older types of transponders (I think ID13 and ID33)
    For all other types of transponders , you can use ZedBull only to prepare them, and after that you have to register new transponders to the car through OBD.
    The Tab "Read/Write" reads only the basic informations of the transponder. It has the same function as R button and W buttons on the real (hardware) ZedBull device.
    You can use ImageGenerator for preparation of ID40, but after that it has to be registered to the car via OBD. No cloning option.
    Best regards
  7. The Following 2 Users Say Thank You to Duracell2 For This Useful Post:
    parrot1964 (8th November, 2017), speedy100 (28th June, 2017)
  8. #6
    May 2015
    argentina
    Quote Originally Posted by trinicolin View Post
    Hello my friend, my zedbull did not work.I had to change the 7805 that powers the screen and I think it feeds the antenna too.Now works 10.
  9. The Following User Says Thank You to pablobonome For This Useful Post:
    trinicolin (21st September, 2017)
  10. #7
    Feb 2014
    You make the manual and we will give you lots of Rep and Thanks to you
  11. #8
    speedy100's Avatar
    Jul 2010
    Athens
    Quote Originally Posted by autoTkey View Post
    I would have done so but keys is not my primary activity so i have many many questions myself...
  12. #9
    Oct 2014
    Netherlands
    Did anyone ever use EFfi to write CS bytes to a prepared TP23 transponder, and successfully learn it in a Passat 3C/B6 (CCM) ?
  13. #10
    Oct 2014
    Netherlands
    Is original Zedbull software or EFfi able to overwrite transponder ID ?
    I tried sending write page command directly but it didn't work. However with Vagtacho I was able to overwrite ID ..
  14. #11
    EARTH
    Happy for the new Sierra project. congratulations.
  15. #12
    Jan 2010
    Cheshire, UK
    Hi where can i download / purchase the latest version of eefi??? and will it precode fiat 7946 remote from eeprom dump?? thankyou in advance
  16. The Following User Says Thank You to AutoX4242 For This Useful Post:
    sktanphg (12th September, 2018)
  17. #13
    Dec 2016
    Hello
    now we waiting Eprog.exe !
    my S N : 45466649
  18. #14
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    Hello,
    Problem with EFFI and MAZDA 2 ECU SID804.
    EFFI not recognize dump.
    Using TANGO and TMPRO is Ok.
  19. #15
    Jul 2017
    France
    hello,
    zed bull read the ducati key T5 id12 : C1 79 1E 00 00 00 00 60
    please how to find the key logic for dash modification ?
    (the key have to start with "F0 00 ....")
  20. The Following User Says Thank You to DCT748 For This Useful Post:
    euroscan1 (22nd December, 2017)
