Page 142 of 147 FirstFirst ... 4292132137138139140141142143144145146147 LastLast
Results 2,116 to 2,130 of 2204
  1. #2116
    Mar 2013
    Patagonia Argentina
    Quote Originally Posted by speedy100 View Post
    Case study...
    What is this [Read&Write] screen exactly doing?
    For example what will it do for a Corsa C ? Will it prepare a PCF7935 to start the car (cloning) or it will need further coding via OBD ?
    hi speedy, that fuction is already in effi! look for "image generator - 40 opel"
  2. The Following User Says Thank You to nicocr For This Useful Post:
    speedy100 (27th June, 2017)
  3. #2117
    speedy100's Avatar
    Athens
    Quote Originally Posted by nicocr View Post
    hi speedy, that function is already in effi! look for "image generator - 40 opel"
    Thank You nicocr for Your reply.
    My question is about the Tab (screen) -Read & Write- in EFfi. What is the function there? Is it cloning a transponder that is ready to start the car or it will need further coding via OBD and diagnostics like OpCom etc.?
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  4. #2118
    speedy100's Avatar
    Athens
    Quote Originally Posted by whiskeyman View Post
    dont take this the wrong way but.....................
    i can write a manual how to work spanners and there uses
    but untill you get hands on and use
    then you really understand its uses and what you need it for
    Here is evidence that a manual is needed... read the reply this poor guy got from an idiot...
    http://www.digital-kaos.co.uk/forums...rator-function
  5. #2119
    Feb 2014
    You make the manual and we will give you lots of Rep and Thanks to you
  6. #2120
    speedy100's Avatar
    Athens
    Quote Originally Posted by autoTkey View Post
    I would have done so but keys is not my primary activity so i have many many questions myself...
  7. #2121
    Duracell2's Avatar
    Apr 2017
    The question is from me and this guy has always the same answer "go to locksmith"
    I answered now my own questions in this thread.
  8. #2122
    Duracell2's Avatar
    Apr 2017
    Case study...
    Preparation and cloning are 2 different things.
    Preparation just writes minimum amount of data to the transponder to be validated by the car as valid transponder.
    After the registration to the car, the car writes also own data to the transponder and locks it.
    ZedBull can only clone few older types of transponders (I think ID13 and ID33)
    For all other types of transponders , you can use ZedBull only to prepare them, and after that you have to register new transponders to the car through OBD.
    The Tab "Read/Write" reads only the basic informations of the transponder. It has the same function as R button and W buttons on the real (hardware) ZedBull device.
    You can use ImageGenerator for preparation of ID40, but after that it has to be registered to the car via OBD. No cloning option.
    Best regards
  9. The Following 2 Users Say Thank You to Duracell2 For This Useful Post:
    parrot1964 (8th November, 2017), speedy100 (28th June, 2017)
  10. #2123
    Oct 2014
    Netherlands
    Did anyone ever use EFfi to write CS bytes to a prepared TP23 transponder, and successfully learn it in a Passat 3C/B6 (CCM) ?
  11. #2124
    Oct 2014
    Netherlands
    Is original Zedbull software or EFfi able to overwrite transponder ID ?
    I tried sending write page command directly but it didn't work. However with Vagtacho I was able to overwrite ID ..
  12. #2125
    May 2015
    argentina
    Quote Originally Posted by trinicolin View Post
    hi guys now tried to use my Zed Bull [Zed-Q x plus] for the first time and it is not recognizing any transponder. Has anyone come across this situation. I need to know how to solve this problem. thanks guys
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Hello my friend, my zedbull did not work.I had to change the 7805 that powers the screen and I think it feeds the antenna too.Now works 10.
  13. The Following User Says Thank You to pablobonome For This Useful Post:
    trinicolin (21st September, 2017)
  14. #2126
    May 2015
    argentina
    Quote Originally Posted by sierra View Post
    Hello.
    The project will probably be revived
    So far, everything is in the alpha version, I hope that 1-2 months will suffice for me to release a stable version. After that new modules will be added.
    I can not often appear on the forum, but about any changes in the project will be unsubscribed.
    Hello friend, where can you download this beauty? I would love to try it.
  15. #2127
    badenaleks's Avatar
    Feb 2012
    Windy City
    Not only you want to try it !!!
    I would also like to!
    Have patience!
    Everything will be okay!
  16. #2128
    EARTH
    Happy for the new Sierra project. congratulations.
  17. #2129
    Cheshire, UK
    Hi where can i download / purchase the latest version of eefi??? and will it precode fiat 7946 remote from eeprom dump?? thankyou in advance
  18. The Following User Says Thank You to AutoX4242 For This Useful Post:
    sktanphg (12th September, 2018)
  19. #2130
    Dec 2016
    Hello
    now we waiting Eprog.exe !
    my S N : 45466649
