Page 145 of 147 FirstFirst ... 4595135140141142143144145146147 LastLast
Results 2,161 to 2,175 of 2204
  1. #2161
    Feb 2014
    Yes, 4D from Xhorse is most suitable for VVDI KeyTool. It doesn't work with TPX2 and I don't think it ever worked.
  2. #2162
    Becoacamba's Avatar
    AnyWhere
    has anyone tested bmw cas (1,2,3,3+) modules?
    regards
  3. #2163
    Becoacamba's Avatar
    AnyWhere
  4. #2164
    droidwayne65's Avatar
    Aug 2015
    North America
    I've done it with CAS2 before.EFfI has a bug, where it zeroes out the data that it prompts you to save. However, there's a simple workaround for that: search the ram of "EFfI.dll", copy and paste the data to make a new file . EFfI usually loads a copy of the original file then generates an altered one in ram. Using your file, this is what it generates when a key, IDE 7E CD 6F 97, is added as key4. Note that this is a locked key, belonging to another car, used solely for the purpose of demonstration.
    <---- Coin of the Realm.
  5. The Following 2 Users Say Thank You to droidwayne65 For This Useful Post:
    Becoacamba (15th July, 2019), Romcik (3rd May, 2020)
  6. #2165
    Sep 2018
    Hello. I need to make a key to volvo fh13 2006 immo box 93c66. all keys lost. I use vvdi2 and super chip but car not start. vvdi gives info that it made the key but it doesn't work. The key reading in vvdi2 is id33, and in mini key toll is id44. It gives the immo box 93c66 reading. Please enter key id and file organization in key. Picture
    vvdi shows 3 keys 1 and 568f9f39
    2 id 56f2aa54 3 id 5661ec83
    Vvdi doesn't make rewritte 93c66
  7. #2166
    Oct 2013
    Serbia,Mladenovac
    VVDI2 show transponder 7935,if you use VVDI SUPER CHIP,dont need rewritte 93c66 just mark used position and make dealer key
  8. #2167
    Sep 2018
    I used a new clean pcf7935AA transpoder dump looks the same as for a super chip. I will start tomorrow, the track is 20 km away.
    Can you check if vvdi reads key id from immo box 93c66 correctly?
    Is the dump correct?
    Has anyone checked the immo off solutions for volvo fh13 2006 bosch ecu?
  9. #2168
    Sep 2018
  10. #2169
    May 2018
    hola amigos estoy buscando un firmware 5.02 de zed bull , alguien me podria ayudar ?
    gracias
  11. #2170
    May 2018
    Default firmware 5.02 zed bull
    5.02, alguien
    hi friends i am looking for a zed bull firmware 5.02, could someone help me?thanks
  12. #2171
    Nov 2015
    UK
    Im learning to eeprom Honda Motorcycles.
    Can anybody supply me please with some eeprom files.
    Mini Zed Bull with EFFI software installed 173 modules
    Many thanks & have a nice day.
  13. #2172
    Nov 2015
    UK
    Afternoon,
    Can i ask for some advice please.
    After creating a new key & saving the Bin file if i then open it up i then see Kawasaki ?
    The key /Bin was for Honda 93C66
  14. #2173
    Feb 2019
    NIGERIA
    Hi guys, Please can someone help me on how to get the original and updated EFFI software
    Thanks in anticipation of your help !
    <<<<<<--------KINDLY HIT THE THANKS BUTTON IF THIS POST HAS BEEN USEFUL TO YOU
  15. #2174
    Feb 2014
    You need to contact Michael (Sierra) about it. Otherwise you won't be able to use it because it is protected by a paid license.
    Or just download the cracked version everyone uses.
  16. #2175
    Agilechaveiros's Avatar
    Oct 2012
    São Paulo -SP -Brasil
    [QUOTE = autoTkey; 3946489] Você precisa entrar em contato com Michael (Sierra) sobre isso. Caso contrário, você não pode aparecer-lo porque está protegido por uma licença paga.
    Ou apenas baixe a versão crackeada que todos usam. [/ QUOTE]
    a very difficult task, I bought the license myself in the past and when I need to talk to him later I tried several times without getting an answer
