masterbol (2nd October, 2019)
Hi Sierra, a huge thank you for the great work you are doing here mate! Much appreciated.
Hi Mr. Sierra.
It is possible to make the software compatible with windows 7?
Congratulations for the excellent work.
Best Regards
Jean
Honda:
[ame=http://www.youtube.com/watch?v=H254_QHdbqA]Honda - YouTube[/ame]
Opel:
[ame=http://www.youtube.com/watch?v=C2bUKnJods0]Opel - YouTube[/ame]
4D:
[ame=http://www.youtube.com/watch?v=uum2tApjoBw]4D - YouTube[/ame]
Can you tell in detail what the problem is?
PS: Found one oddity in Image Generator -> 67
Wrote correctly, but some recorded transponders ZED-Bull defines as 63 or 68
By this, I made two versions - Old and New.
You can use both, but in the New is not always correctly identifies the ZED-Bull.
You can download it from the first message of this topic (EFfI.rar)
litle help to understand the programmed way for the key for clio2 id46.i take empty 7936 iread dump from uch and i manual write the isk low and hi only and i check in hitag crypto like the picture and then write?or like module 42 and then i make somethink?thanks
if i preprogrammed in module 42 for clio then i can t see in hitag.is locked.how i check the crypto.sorry for so many questions.i destroy about 6 chip for this clio.i send my dump from my key can you give me a sample.thanks
i found the code with true code but i want to programmed empty 7936 only for immo and not for remote.how i can do it?the keys in clio broken the antena coil and don t start the car.so how i can do this ?i found isk and i put manual in hitag the hi and low in crypto mode?and then programmed in car with clip or true code.or i must take new key 29 pounds from 3dgroup and programmed?because some time i need only for immo.thanks
I still encounter the same problem with the new softwareversion (error 9 after 5 unlocking attempts) - i guess this only applies to ID48 Crypto Magic1 versions, the Magic2 transponders can be unlocked without problems (like with ZedBull software)
Sierra - can you tell if it's possible to unlock Magic 1 ID48 transponders too?
That would be a great feature for your fabulous software !
Thanks a lot for your great work !
Best regards,
yellowstilo
i think the same.but i see that said it could be with the 7936 in crypto mode and put isk high and low.but manual?see some posts before.gepacg have do it a lot said.i want with 7936 carbon chip i want.i have see and clio with only chip carbon inside and not remote.the cheap version
i dont understand your problem,simply load dump into module 42,make transponder programming and he will automaticly write crypto hi-lo and switch it to crypto mode,than you get pin code and with any tool like ad100,sbb,clip pcf7936 will be progammed without problems,all of this and exactly sierra sw module tested and report yesterday,than it work for 100%!!!
if you program pcf7946 no need preparing crypto pages,only page 6 for remote sychro functions
regards Gepa
