Thanks your helps, it is working! Tomorrow I will try to program new transponder for the car. Does EFFI can calculate this PIN?
Chokito5 (24th September, 2013)
I am not a masterI tried to program transponder to the Clio, but I couldn't
The original key is a PCF7946 (on board) ID46. I tried to program it to preprogramed ID46 (PCF7936 chip, AD900 did the preprograming), to blank ID46 chip. The programing was unsuccessful.
Which chip is good for this car???
I think I need money for EFFI![]()
Chokito5 (25th September, 2013)
I found a zed bull clone that is about 2 yrs. old and never been use. How can I upgrade these unit with Sierra labor of love? I was very happy to find these early model clone,as I hear the new one have issues.
I tried to program PCF7936 for Clio with SBB and CAN CLIP too, I couldn't do it.
Maybe the car immo has other problem. Today I turned on the ignition without any transponder, and the RED led (immo led on the dashboard) light on, not flash. I think it is any other mistake. The RED led need to flash fast when there is not any transponder. Maybe this thing that I can't program any transponder for this car.
Earlier when I turned ignition on with the original key, very seldom the car started, but nowadays I can't start with the original key neither![]()
try to turn on ignition without any transponder in key, does light flash? if stay on then you have other issue, and sometimes after programming, the uch will lock you out, leave ign on for 1 min with red led on solid, then turn off and turn straight to crank and car will start if everything is ok.
ps - you need to pre code pcf7936 AND program with pincode after, better to use a new pcf7946 on a used remote, pre code with effi or zed clone and program with pin code.
ninja
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
gwee (26th September, 2013)
Did not see Kawasaki in EFFI, hope that it will be there soon![]()
Hello, would this work with an Renault Logan uch siemens 93c66, ready to start the car?
Chokito5 (27th September, 2013)
