Today I try to make key to a Renault Espace year 2002.
I read Hc08 mask j35d from Bsi,EFfi recognize my dump ok ,prepare transponder pcf7935 but engine not start.
I think the logic is not ok in this module.
Here is dump,please I need some advice or help.
Your dump damaged. You can will be convinced if you count pin code.
Read a trasponder who wrote down and send me a screenshot.
treo, Load this dump into the program and write down a transponder. Try to start the car.
Write about result.
This is data from transponder.
Now I try to write new data from you and I will come back with news.
Thank you.
Here is printscreen
treo (16th December, 2013)
Is Ok .
With your data engine start.
You are the Man.
sierra (16th December, 2013)
Indeed, there is a bug in the module 84 for MC68HC908AZ64. The error was in the original Zed-Bull and passed to me by inheritance in EFfIFixed.
Atex31 (17th December, 2013), badenaleks (17th December, 2013), cjawahir (16th December, 2013), daniersms (16th December, 2013), gwee (16th December, 2013)
Hi!
Can somebody confirm me that module 113 fully work in EFfi,it is from BMW motorcycle ECU med17,based on new TriCore eprom MCU?
regards Gepa
gepakg (17th December, 2013)
the module, is for bikes, where keys are in ECU not in the ignition lockthe first BMSX models came with keys in ECU in tricore. the latter modules were made with EWS, with ignition lock.
look at BMW parts if you have keys in ECU or ignition lock
MACKIE (18th December, 2013)
Had a toyota yaris 2004 - 4c key - ECU 93c56 chip, didn't work on effi or tagtool, had to purchase modual on other unit.
