Page 18 of 147 FirstFirst ... 813141516171819202122232868118 ... LastLast
Results 256 to 270 of 2204
  1. #256
    Jan 2010
    Quote Originally Posted by euroscan View Post
    - thanks, now is working. - but if i read id48 transponder.mdb or Car show Honda , not Alfa Romeo.
    You can add your own in transponder.mdb your desired car.
  2. #257
    Jan 2010
    Quote Originally Posted by dam495 View Post
    opel 2 with tms okay fiat 93lc66 okay transponder produce fail pfc 7936 tryed to produce honda failed, nissan failed, opel failed, tryed to produce texas 4d 63 to eh2 fail, texas d67 failed
    Tomorrow I'll check, but I recorded 4D67 at EH2, had no problems.
  3. The Following User Says Thank You to sierra For This Useful Post:
    masterbol (2nd October, 2019)
  4. #258
    Fallen's Avatar
    Dec 2009
    Hi Sierra, a huge thank you for the great work you are doing here mate! Much appreciated.
  5. #259
    Top Poster Jeanhdo's Avatar
    Aug 2009
    Brasil-S?o Paulo
    Hi Mr. Sierra.
    It is possible to make the software compatible with windows 7?
    Congratulations for the excellent work.
    Best Regards
    Jean
  6. #260
    Jan 2010
    Honda:
    [ame=http://www.youtube.com/watch?v=H254_QHdbqA]Honda - YouTube[/ame]
    Opel:
    [ame=http://www.youtube.com/watch?v=C2bUKnJods0]Opel - YouTube[/ame]
    4D:
    [ame=http://www.youtube.com/watch?v=uum2tApjoBw]4D - YouTube[/ame]
    Can you tell in detail what the problem is?
    PS: Found one oddity in Image Generator -> 67
    Wrote correctly, but some recorded transponders ZED-Bull defines as 63 or 68
    By this, I made two versions - Old and New.
    You can use both, but in the New is not always correctly identifies the ZED-Bull.
    You can download it from the first message of this topic (EFfI.rar)
  7. #261
    Jan 2010
    Quote Originally Posted by micromax View Post
    sierra you can add nissan pin code from label like this - http://www.digital-kaos.co.uk/forums...s-help-294306/
    and bmw cas support?
    If someone would give me the algorithm, I add
    Now the main thing for me to fix all the errors that is.
    With your help, they become smaller, but they still have.
  8. #262
    Dec 2009
    litle help to understand the programmed way for the key for clio2 id46.i take empty 7936 iread dump from uch and i manual write the isk low and hi only and i check in hitag crypto like the picture and then write?or like module 42 and then i make somethink?thanks
  9. #263
    Dec 2009
    if i preprogrammed in module 42 for clio then i can t see in hitag.is locked.how i check the crypto.sorry for so many questions.i destroy about 6 chip for this clio.i send my dump from my key can you give me a sample.thanks
  10. #264
    coolsoda's Avatar
    Apr 2008
    Scotland
    Quote Originally Posted by tas_daz View Post
    in renault clio i make transpoder and then with true code and with clip i can t programmed the key.you try with sbb nad you programmed in chip with dump from uch with zed bull?in carbon chip?sierra if you find solution for clio it is very good.thanks for all your work
    You have True Code and Zed Bull,why are you using module 42.
  11. #265
    Dec 2009
    i found the code with true code but i want to programmed empty 7936 only for immo and not for remote.how i can do it?the keys in clio broken the antena coil and don t start the car.so how i can do this ?i found isk and i put manual in hitag the hi and low in crypto mode?and then programmed in car with clip or true code.or i must take new key 29 pounds from 3dgroup and programmed?because some time i need only for immo.thanks
  12. #266
    yellowstilo's Avatar
    Nov 2009
    - Error 9 if i try unlock ID48 for alfa romeo.
    - zed-buul 5.08 do it.
    - i make lock by change Word1 from 0E16 to 4E16.
    I still encounter the same problem with the new softwareversion (error 9 after 5 unlocking attempts) - i guess this only applies to ID48 Crypto Magic1 versions, the Magic2 transponders can be unlocked without problems (like with ZedBull software)
    Sierra - can you tell if it's possible to unlock Magic 1 ID48 transponders too?
    That would be a great feature for your fabulous software !
    Thanks a lot for your great work !
    Best regards,
    yellowstilo
  13. #267
    coolsoda's Avatar
    Apr 2008
    Scotland
    You can not produce a working pcf7936 from dump,you need a TPX4 chip,all PCF7936 have unique serial number your car does not recognize this therefore you have to program them in,and if your pickup coil does not work so you cant do this.
  14. #268
    Dec 2009
    i think the same.but i see that said it could be with the 7936 in crypto mode and put isk high and low.but manual?see some posts before.gepacg have do it a lot said.i want with 7936 carbon chip i want.i have see and clio with only chip carbon inside and not remote.the cheap version
  15. #269
    gepakg's Avatar
    Feb 2010
    Serbia
    i dont understand your problem,simply load dump into module 42,make transponder programming and he will automaticly write crypto hi-lo and switch it to crypto mode,than you get pin code and with any tool like ad100,sbb,clip pcf7936 will be progammed without problems,all of this and exactly sierra sw module tested and report yesterday,than it work for 100%!!!
    if you program pcf7946 no need preparing crypto pages,only page 6 for remote sychro functions
    regards Gepa
  16. #270
    Jan 2010
    Quote Originally Posted by yellowstilo View Post
    Best regards,
    yellowstilo
    I also can not unlock Magic1. Zed-Bull clone also can not unlock.
    Who knows, Zed-bull original can unlock Magic1?
