Page 86 of 147 FirstFirst ... 3676818283848586878889909196136 ... LastLast
Results 1,276 to 1,290 of 2204
  1. #1276
    Oct 2011
    Hungary
    Thanks your helps, it is working! Tomorrow I will try to program new transponder for the car. Does EFFI can calculate this PIN?
  2. #1277
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by Chokito5 View Post
    Of course !!
  3. The Following User Says Thank You to gwee For This Useful Post:
    Chokito5 (24th September, 2013)
  4. #1278
    Oct 2011
    Hungary
    I am not a master I tried to program transponder to the Clio, but I couldn't
    The original key is a PCF7946 (on board) ID46. I tried to program it to preprogramed ID46 (PCF7936 chip, AD900 did the preprograming), to blank ID46 chip. The programing was unsuccessful.
    Which chip is good for this car???
    I think I need money for EFFI
  5. #1279
    gwee's Avatar
    Dec 2012
    unknown
    Get EFFI from sierra, all your problem solved
  6. The Following User Says Thank You to gwee For This Useful Post:
    Chokito5 (25th September, 2013)
  7. #1280
    ray-ray's Avatar
    Nov 2009
    I found a zed bull clone that is about 2 yrs. old and never been use. How can I upgrade these unit with Sierra labor of love? I was very happy to find these early model clone,as I hear the new one have issues.
  8. #1281
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    You can use PCF7936 on Renault CLIO.
    You MUST use PCF7946 and prepare it with EFFI or ZED bull soft.
  9. The Following User Says Thank You to didi_du_93000 For This Useful Post:
  10. #1282
    Oct 2011
    Hungary
    Quote Originally Posted by didi_du_93000 View Post
    I tried to program PCF7936 for Clio with SBB and CAN CLIP too, I couldn't do it.
    Maybe the car immo has other problem. Today I turned on the ignition without any transponder, and the RED led (immo led on the dashboard) light on, not flash. I think it is any other mistake. The RED led need to flash fast when there is not any transponder. Maybe this thing that I can't program any transponder for this car.
    Earlier when I turned ignition on with the original key, very seldom the car started, but nowadays I can't start with the original key neither
  11. #1283
    Jul 2010
    west mids, uk
    try to turn on ignition without any transponder in key, does light flash? if stay on then you have other issue, and sometimes after programming, the uch will lock you out, leave ign on for 1 min with red led on solid, then turn off and turn straight to crank and car will start if everything is ok.
    ps - you need to pre code pcf7936 AND program with pincode after, better to use a new pcf7946 on a used remote, pre code with effi or zed clone and program with pin code.
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  12. The Following 2 Users Say Thank You to ninja123 For This Useful Post:
    Chokito5 (27th September, 2013), gwee (26th September, 2013)
  13. #1284
    Jul 2010
    west mids, uk
    Quote Originally Posted by gwee View Post
    Started a 2004 passo with module 105, auto detected, worked perfect. thanks to Andrius
    hi gwee, Did you get any pictures for sierra to add to effi?
    ninja
  14. The Following User Says Thank You to ninja123 For This Useful Post:
  15. #1285
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by ninja123 View Post
    ninja
    Did not think about that Good idea! Will start collecting pictures.
  16. #1286
    gwee's Avatar
    Dec 2012
    unknown
    Did not see Kawasaki in EFFI, hope that it will be there soon
  17. #1287
    Jan 2010
    You have dumps from Kawasaki?
  18. #1288
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by sierra View Post
    Yes, will email you
  19. #1289
    DK Veteran viejomatius's Avatar
    Jun 2009
    Hello, would this work with an Renault Logan uch siemens 93c66, ready to start the car?
  20. #1290
    Dec 2009
    France Paris
    Sorry i have make mistake on my reply.
    YOU CAN'T LEARN A PCF7936 ON CLIO 2.
    MUST USE PCF7947.
    Don't lose your time
  21. The Following User Says Thank You to didi_du_93000 For This Useful Post:
