inlock (12th August, 2020)
try this it will work .
if the keys are sychronize to immobox it will work.
use any similar file of your memory that you will find in dk .
make a bridge between 4pin and 13 pin in obd .
open the ignition .
leave it one hour .
remove bridge
open close ignition and enjoy
What exactly was wrong with the car originally? The file i gave you should work but if it did not its because you probably dont have a good dump for the immobox. Immo wont ask for a particular number except you are saying the original part number of the immobox is 89780-71020 and if that is it, then here it is
Sent from iPhone 4S
Sogaro, you're good! Im getting somewhere now. It is now giving me an unregistered key error. How do you program a new master key in this thing?
If someday this Toyota works its a good idea donate the 50$ to DK support.
DAMMIT here, try LEECHING this, remember to donate the $50 to DK anyway. http://www.digital-kaos.co.uk/forums...3/#post1372217
try this file and immediately send a donation to the DK forums.
89780-71020_01
second option:
short between pin 4 & 13 in obd
third option:
post here ecu, immo & key data.
texasmeat (1st July, 2014)
I've done the pin 4 and pin 13 thing and no go. What is the password for the file you have bram?
@Texasmeat, may I ask what key you are using for this car? Kindly post the key data info here so we can know for certainty you have the correct key. The file I recently gave is virgin, it's got no keys in it so you have to do an Autoreg of keys, but now , let's see your key data. Cheers.
Sent from iPhone 4S
what you have is a total miss match , the immo module you have is from a usa model tachcoma truck .
i have an ecu for ikdftv non immo , ill see if i can read it and you can try it , but you need to disconnect the immo and transponder .
the part number for you engine ecu is showing as a TOYOTA FORTUNER .
cj
