post the original file here.
I don't have the original unfortunately. File was damaged and deleted. I attempted a immo off and none have worked. I'm at the virgin ecu stage I think.
Is that the same file from this thread?
http://www.digital-kaos.co.uk/forums...-100-a-270587/
If so, I've tried that one already and it doesn't work. Keep getting a no-start condition with a B2799 engine immobilizer code.
You must sincronize immo to ECU.
post here ecu & immo dump
You can use this file, make your key from your immobox and then sync with this ECU file. Hope you know how to do that?
Sent from iPhone 4S
texasmeat (1st July, 2014)
Thank you for all your help so far! I will try this file and post up results. I have put the immo ecu into auto registration mode. Just to be sure, how do I get the key code from my immobox?
If immobox is in Autoreg mode, put your key fOr 10s to register it and the after do the 30mins minimum ECU to immo reg
Sent from iPhone 4S
You guys are great. I will post back later. Thanks
