Results 1 to 3 of 3
Hybrid View
    Sep 2008
    Default SSL84 down to SSL82
    Hi All
    I have an image which installs SSL84 I have a problem where when I updated the channel list online I lost the tuner some people are saying its a problem with SSL84 so my question is can you install an image which is SSL84 and downgrade to SSL82?
    Also what is the difference between SSL82, SSL84A and SSL84B
    DK Veteran Bann32's Avatar
    Oct 2011
    Northwest
    im not sure its a problem as such you just rescan the box and it should be ok then, ive never had a problem after doing the inital install of a boquet and scan on any image that uses the ssl84 bootloader
    Nov 2010
    afaik - ssl 84 is the original version, 84a and 84b are patched versions for cloned boxes
