im not sure its a problem as such you just rescan the box and it should be ok then, ive never had a problem after doing the inital install of a boquet and scan on any image that uses the ssl84 bootloader
Hi All
I have an image which installs SSL84 I have a problem where when I updated the channel list online I lost the tuner some people are saying its a problem with SSL84 so my question is can you install an image which is SSL84 and downgrade to SSL82?
Also what is the difference between SSL82, SSL84A and SSL84B
afaik - ssl 84 is the original version, 84a and 84b are patched versions for cloned boxes
