Results 1 to 8 of 8
    Default CDF FILE ON EUROVOXEX7000HD
    I HAVE THE CDF FILE FROM MY EUROVOX MAX CAN I USE IT ON THE EX7000HD THANKS
    DK Veteran gadgetfiend's Avatar
    Aug 2008
    nope you cant unfortunately m8
    DK Veteran Lanxman's Avatar
    Lancs
    I haven't figured out how to create the channel.tbn file on a flash drive yet, Any idea how to do that gadget?
    Aug 2008
    check other post m8
    Jan 2009
    on the file transfer on the box you press the green button to upload to channel.tbn.
    take the usb out and put in pc,
    use the ex7000 editor and you can change it in there and save it back to the usb, plug back into the ex700 box and upload from data transfer and there you go
    Lancs
    Quote Originally Posted by mike281180 View Post
    I tried that, didn't seem to work for me. Not at home at the moment but when I get back i'll have another bash mate
    Cheers.
    Jan 2009
    I am having similar issues...
    as a cdf file doesnt work.... and the flash file for the firmware is a tbn file - does this mean that the channel guide is built into the firmware?
    i have tried opening up the tbn file in stbm... just gives message please select channel, when edit pressed.... very confused ...?
    Jan 2009
    aha - worked this one out - when you see files scroll left to view the channel file - I was uplaoding the wrong file - didnt notice the scroll to right function -
    Alll sorted now and editing on PC -
    Trouble is as mentioned in other thread...
    There is no update button in menu for when channels move...???
