Results 1 to 5 of 5
Thread: Mazda 5 DPF off
    DK Veteran VTS_Tibi's Avatar
    Hungary
    Default Mazda 5 DPF off
    Hi Guys,
    I have a Mazda 5 here which needs the DPF to be removed.
    The ECU is Denso RF7N.
    I've attached the original file, which was read out using Piasini and the connections were made according to the "Mazda-dci" pdf instruction. So this is not the usual Mazda - Denso ECU.
    Naturally I'm willing to pay for a correct, working solution without a DPF and check engine light and error codes. And also no regeneration after a certain km.
    z786's Avatar
    10 Steps Ahead of You
    pm ecutuners mate
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Hungary
    Quote Originally Posted by z786 View Post
    pm ecutuners mate
    Did that and Danny solved a smoking diesel AGAIN!
    Jul 2012
    BG
    You just write the file into ECU or you need to use some procedure? Thanks
    Hungary
    Just write the dump into the ECU and it was ready to go
