Results 1 to 12 of 12
    DK Veteran 70max's Avatar
    May 2012
    Default Help file 1_3 gp mod
    Hello Friends,
    ECM and valid driver for this file?
    The car is:GP MJT 1_3 HP 75
    I can indicate the increases in the relative maps to a good job.
    Thanks to everyone that I meet
    greetings
    May 2011
    Do you want a prof tun file for it?
    so you only need map addresses?
    May 2012
    Default Gp
    Quote Originally Posted by quattrotr View Post
    If you want,
    Or just increases the file then the mod myself.
    Quote Originally Posted by ominimicu View Post
    I wanted info if there are other hidden maps that the driver does not know.
    greetings
    carmageddon's Avatar
    Italy
    not so simple find really good and genuine information...
    May 2012
    Default Gp
    Quote Originally Posted by carmageddon View Post
    Thanks for your response you can give me info,
    Seeing the file, I can indicate the correct maps?
    and if you can advise me increases.
    Thank you.
    greetings
    Italy
    i can not give info to final user, only to developer
    May 2012
    Default gp
    I am a developer, I made the mjt 70 hp and are happy,
    But I'm not convinced that this is 75 hp more than the fact I'm in the press turbo
    and I wish there was some other map that I do not know and by increasing the turbo will not do anything.
    my uncertainty is that if you can advise me thank you even now.
    greetings
    Italy
    if you were developer not asked information about this work here!
    maybe you work with chiptuning but you are not a developer!
    Italia
    Quote Originally Posted by 70max View Post
    Hello Friends,
    greetings
    My drivers for ecm 6.3!
    May 2012
    Default gp
    Quote Originally Posted by AlfaRed View Post
    Alfared thank you very much,
    I sought help in this way, I do not care to be as developer CARMA says ....
    Greetings to all
    Italy
    with this driver you can get little power and not in correct mode...3/4 of really important maps is missing.
