Page 6 of 6 FirstFirst 123456
Results 76 to 89 of 89
  1. #76
    i suppose its all still in its infancy stage and will be great once its all sorted out as long as the powers that be don't get to shut it down !!!
  2. #77
    Apr 2012
    Can 1channel be paused so that the download resumes in the background, as you would do when watching something on YouTube ? Mine always seems to be very choppy due to my crappy 4mb sky connect, throttled connection.
  3. #78
    DK Veteran eattheliving's Avatar
    Nov 2008
    Quote Originally Posted by Bumsrus View Post
    yes it can be paused. i think i left mine for approx half an hour then resumed play the other day.
  4. #79
    Apr 2012
    Do u know what button you pressed to pause it because the standard pause on the remote doesn't do anything?
  5. #80
    Nov 2008
    Pause button on mine matey
  6. #81
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Pause button on vix and yellow button on blackhole.
  7. #82
    Apr 2012
    Bizarre , neither yellow button or pause work on my blackhole 1.7.6 . Just get the small red error symbol at the top of the screen. However I have discovered if u press standby on the remote, it does pause the film and turn the duo off, but when u switch it back on it starts the film at the beginning again .
  8. #83
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    It sounds like you have not got timeshift on hdd or usb set up.
  9. #84
    Mar 2012
    Is this plugin still working just tried installing it and when I try and watch a movie, it lets me select one and brings up a sever list but if I then select a server it either just takes me to the recorded programmes list or it crashes the box.
    Running a Vu+ Duo with Vix 2.4
    Cheers
    Jim
  10. #85
    Nov 2008
    Quote Originally Posted by JimboM View Post
    Cheers
    Jim
    Hi jim, it was working the other day. what i have found is that this plugin is still a bit cluncky and tempramental. just try some others matey.
  11. #86
    Junior Member reddishd's Avatar
    Borders, West England
    1channel VU+DUO/SOLO plugin is spot on with VIX immage, Still work for Solo Blackhole needed.
    Overall this is a top plugin as gd as i have ever seen.
  12. #87
    Jan 2013
    is this still working?
  13. #88
    Mar 2011
    just downloaded this plugin
    using blackhole 1.7.5 vu+ solo with 320gb usb drive
    works perfectly
  14. #89
    Arrow 1 Channel Plugin-works at 3Mbps.
    Quote Originally Posted by roosk View Post
    Put it on my dm800hd can see all the film list but when going to play one i get the putlocker and sockshare links so i click on one, title of film comes up then blank screen cant get any link working. any ideas please
    You will need a gd wideband 3mbs connection to get the movies working properly.
    If you have that then you have other issues like a plugin not made for the Duo!
