Please don't write - there is a parallel device![]()
You may also disassemblers
If you do not empty (all FF) then search for "UV EPROM eraser." I sent you write in it and replace the original.
VBR.
licho (26th November, 2015), masterskay62 (25th November, 2015), shooting (26th November, 2015)
A little more: the first way the original code, Mr Satmanek post # 3 "Read chip 27C256 two and 52B33" (SEEQ52B33)iqr88_creader.jpg
The second step described above, to be a "window" parallel eprom! not EEPROM. The content of the UV light can be deleted if it is empty I sent you into the content you write and I think that there will be code-free. It's not 100% because it was so long ago that I do not remember ....
vbr
shooting (25th November, 2015)
yes......
Free for all... http://www.ulozto.net/x3tAWwM/blaupu...-decrypter-zip
sanixmen (26th November, 2015)
bingo,code 7289 ok.thanks,thanks,thanks
berlin iqr85
Hi there.
I'm such a service unit.
52b33 data content is damagedTC54256 not damaged.
There is someone working? This must be programmed separately?
Hi.
Can anyone help me to get the Code for my IQR88 Blaupunkt?
BP Calculator wont work - enclosed the eprom Dump
THX
SAM
hello brother
i need radio code for this radio Blaupunkt Berlin
Please share this file, i need decode one radio. Thanks
