Results 1 to 7 of 7
    baltazar3's Avatar
    Andromeda
    Default Alfa 159 2.4 JTDM 210 HP 0 281 014 459 need ori
    Alfa 159 2.4 JTDM 210 HP 0 281 014 459 need ori.
    Here is file that I was found.
    Thanks in advance !
    Top Poster otzi's Avatar
    Austria
    I have only 2 files i hope help you
    BR,
  3. The Following User Says Thank You to otzi For This Useful Post:
    MAYQUAD (3rd November, 2014)
    baltazar3's Avatar
    Andromeda
    Default Alfa
    Its too menu differences....probably need BDM read.Cant figured out..Car have no errors but is to slow and lazy...Think that some1 play with DPF...
    Quote Originally Posted by baltazar3 View Post
    Thanks in advance !
    Hello acnche this file is the original ... regards
  6. The Following 2 Users Say Thank You to mariooo For This Useful Post:
    MAYQUAD (3rd November, 2014), mgtuning (14th May, 2021)
    baltazar3's Avatar
    Andromeda
    Default Alfa
    Quote Originally Posted by mariooo View Post
    Yes ...this is it ....the same like mine.Diferent is MPPS and BDM reading ...but its the same.Thank You all very much !
  8. #6
    ECU HW: 0281014459
    ECU SW: 1037506095
  9. The Following 2 Users Say Thank You to donesko For This Useful Post:
  10. #7
    Default Need Ori File Alfa 159 2.4 JTD Bosch Nr. 0281015229
    Hello@all
    Im searching for a Ori File from Alfa 159 2.4m JTD 20V 210 HP with Automatic Gearbox
    ECU
    1037504039
    Bosch EDC16 C39 0281015229
    Fiat Part. Nr. 51820800
    SW. Nr. 1037504039
    I have one of this file but wehn i write it into the ecu the car dont start i try it with magpro2 clone and FG Tech clone it write up to 100% and both Tools says Checksumm OK But Car dont start.
    The Problem is that the car is tuned from another guy l he do a cramp the Turbo Pressure dont stay it springs alway from 1.2 to 1.5 bar on the full load. And this Guy is is impossible to contact him.
    I newer had a Problem to write th?s Ecu i write more than 40 of this type ECU. i Have Attach the Ori that i read out on a another Car that have the same SW Nr. 1037504039 but with this File the Car dont start.
    But The SW Nr. is the Same Win OLS Says Checksumm OK
    Best thanks for help.
    greeting
    bambula tuner
