Page 33 of 39 FirstFirst ... 232829303132333435363738 ... LastLast
Results 481 to 495 of 575
Thread: PIASINI
  1. #481
    Feb 2011
    Greece-Athens
    What problem you have?
  2. #482
    Apr 2014
    Hounsland
    Reading works perfect, but if I write back to Ecu the program stops at address 60000 and says: reflash done, turn your ign off.. result is that the engine won't start..
  3. #483
    Feb 2011
    Greece-Athens
    Have you try to flash it with the Lancer Ralliart(512k)M32176F4 also download the last version of their software they have fix many bugs version number:1.44.42.47
  4. #484
    Apr 2014
    Hounsland
    I tried with LancerRalliart(512K) but with the old version of this program... I paid a lot of money to fix my ecu after trying to flash with ecuflash..
  5. #485
    Nov 2012
    smartville in front of a OBDplug
    tactrix don't make the checksum correctly with colt turbo !
  6. #486
    moky's Avatar
    Behind you
    just tested 4.3 updates on new sh7059 2013 and no problems with v4.1 never worked..
  7. #487
    Apr 2014
    Hounsland
    Piasini clone doesn't work with colt turbo!
  8. #488
    Top Poster VAGR666's Avatar
    Portugal
    Mine does... it is a simple ecu, direct to plug
    Quote Originally Posted by Houns12 View Post
  9. #489
    Feb 2011
    Greece-Athens
    If somebody flash a file inside with changed the init sequence then piasini tool is not working,it is a simple methology to lock generic tools outside the flash
  10. #490
    Apr 2014
    Hounsland
    Thats possible because when I damaged my Ecu with EcuFlash, a friend repaired it with another tool...
  11. #491
    Riga
    Quote Originally Posted by mysamed View Post
    id JJSW31GVQxmqC0hNQjriePLvxMMvJ7aS
    please thans
    Could you make file for me?
    VNRvfT3KPvvuvRMudqtMztfOwUw=
    PS after windows update ID is changed
    Many thanks,
    Andris
  12. #492
    heteromies
    Guest
    Quote Originally Posted by asid12 View Post
    Many thanks,
    Andris
    Yes, i could. Here, mate!
  13. #493
    hello
    Will help someone in uzuskaniu key to piasini 4.1?
    id QGmZbuV0d8wSizCOg2bCNw==
  14. #494
    heteromies
    Guest
    Quote Originally Posted by tom3212 View Post
    hello
    Here mate, test and report!
  15. #495
    thank you
    works
