Results 1 to 15 of 17
    Default pic of the on off buttom set up? or info
    iv taken it apart as there Wire sparks coming from it on the inside (clone) after the psu blew up , ffs scary but i have a extra psu to try
    all i need to confirm is witch way the wires go on to the power switch
    is the rite
    red one on top on psu goes on the upper left connector
    red one on bottom on psu goes on the upper left conectore
    black one on top on psu goes on the upper right connector
    black one on bottom on psu goes on the upper right connector
    pleases look , upload a pic of you setup
    DK Veteran potrobber's Avatar
    N Ireland
    with the lid of the box and looking at it from front the block of 4 wires the 2 blacks are on left and 2 reds on right this is on connector pushing into psu
    the switch looking at it from front of box has 2 reds on left and blacks on right
    Mar 2011
    Providing that both blacks wires and both reds are on the same side I don't think it matters. So keep both blacks wires on the left and both red wires on the right would also work. When looking at the connector on the PSU itself, again the same thing applies, keep both the same colour on either on the left or the right.
    thanks guys
    on the psu the clip is on the right ???
    Mar 2011
    Quote Originally Posted by the man View Post
    thanks guys
    That's sound like how potrobber has his, the important thing to keep the same colour wire vertically, so the reds are above/below each other and the same for the blacks.
    If you look on aliexpress, search for vu duo free shipping then find a seller called Define, they have pics of the internals and you can just about make out where the wires go.
    N Ireland
    thanks guys
    thats how they leave the factory and will work the other way also as stated by i.a.a.t
    and your clip is correct also
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Have you tested switch to see if it still works?
    how to do that pal? do they brake offten?
    i think the switchs ~~~~ed tbh ,
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    For information only : Do you have a multimeter? line test will beep when switch is on. It won't when off. It won't beep at all in both positions if knackered. [ame=http://www.youtube.com/watch?v=tDQ0X1LRhpg]Dryer Switch Testing - YouTube[/ame]
    Same principal applies to testing your switch. Black pin to Black pin test. Red pin to Red pin test. HTH
    nope , sendng it back , so hope to get a refund thanks pal
    Mar 2011
    Silly question, possibly but have you checked the fuse in the plug?
  13. #13
    yep but had sparks from the on off switch , im calling it a day pal
  14. #14
    Sep 2008
    wise choice i think you dont want your home burnt down,now while we are on that subject,have you tested your smoke alarms??too late you may not be around then.
  15. #15
    will test fire alarms 2morow !
