same problem how to use it
same from me toooo.
how to use it?
cant downL..
Welcome to DK.
This is an old thread so what exactly is your problem, how to use what?
The OP was saying he added games to a USB stick but HBC doesn't recognise them only the bubbles show.
There is an option in HBC when it starts even if you don't have an SD card inserted so you only see the bubbles. If you press button 1 you see Options Device: Internal SD Slot and USB Device. If these games are on a USB stick then try and click on USB Device to see if it reads your games.
sahil2000 - now you've made you first post you should be able to download things from the download section.
Keith
2010 Golf GTD (170)
thx man u realy helped me...
Keith
2010 Golf GTD (170)
Hi guys wonder if someone can help me out I've got usb loader on my Wii and its up and running in HBC ..I've tried getting a game to work on a 16 gig flash drive and in Gx loader it says loading game takes around 6 mins but nothing shows up in the loader except the 10 channels .ie shop/photo's mil .The file is wbfs obviously I missed doing something ..Thanks in advance
I did a systems check if it helps..
sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
...runs on IOS37 (rev 2070).
Region: PAL
System Menu 3.2E (v290)
Drive date: 2007.02.13
Homebrew Channel 1.1.0 running on IOS37
HomebrewFilter ist nicht installiert
Hollywood v0x11
Console ID: 115210867
Boot2 v3
Found 119 titles.
Found 24 IOS on this console. 1 of them are stub.
IOS4 (rev 3): Stub
IOS9 (rev 516): Flash Access
IOS11 (rev 10): Trucha Bug ES Identify Flash Access NAND Access
IOS12 (rev 6): Trucha Bug ES Identify Flash Access NAND Access
IOS13 (rev 10): Trucha Bug ES Identify Flash Access NAND Access
IOS14 (rev 257): Trucha Bug ES Identify Flash Access NAND Access
IOS15 (rev 257): Trucha Bug ES Identify Flash Access NAND Access
IOS16 (rev 257): Trucha Bug ES Identify Flash Access NAND Access
IOS17 (rev 512): Trucha Bug ES Identify Flash Access NAND Access
IOS20 (rev 12): Trucha Bug ES Identify Flash Access NAND Access
IOS21 (rev 514): Trucha Bug ES Identify Flash Access NAND Access
IOS22 (rev 772): Trucha Bug ES Identify Flash Access NAND Access
IOS28 (rev 1288): Trucha Bug ES Identify Flash Access NAND Access
IOS30 (rev 1039): Trucha Bug ES Identify Flash Access NAND Access
IOS31 (rev 1040): Trucha Bug ES Identify Flash Access NAND Access
IOS33 (rev 1040): Trucha Bug ES Identify Flash Access NAND Access
IOS34 (rev 1039): Trucha Bug ES Identify Flash Access NAND Access
IOS35 (rev 1040): Trucha Bug ES Identify Flash Access NAND Access
IOS36 (rev 1042): Trucha Bug ES Identify Flash Access NAND Access
IOS37 (rev 2070): ES Identify
IOS51 (rev 4633): Trucha Bug
IOS249[38] (rev 17): Trucha Bug ES Identify NAND Access USB 2.0
IOS250 (rev 65535): Trucha Bug ES Identify NAND Access USB 2.0
IOS254 (rev 65281): BootMii
BC v2
MIOS v5
Report generated on 2013/02/02.
That doesn't look like a full sysCheck there are IOS's missing, post a full one as instructed in sysCheck19
Keith
2010 Golf GTD (170)
Hi Keith thanks for replying I did use sysCheck19 that I downloaded from this site after I'd read the earlier comments in this thread ????? and if you look it says found 24 IOS any ideas why as you say IOS are missing and what I can do about it ..Thanks again
Sorry I've just noticed its 3.2 so there probably are a few IOS's missing I have 55 in my 4.3, this was a quick post before I went out for the evening.
Anyway if you want to play games from a stick or drive then you need more IOS's installing.
You need to download ModMii6.2.6 and run it from Windows. Now you have the sysCheck.csv file from the sysCheck which will be on the root of the SD card you can choose the SU option from the main menu. Type in the location of sysCheck.csv.
This will download all files into COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted. ModMii only adds 2 d2x v8.0 wads so install all 7 wads from d2x v8.0 final wad pack after you've added them to the wad folder on the SD card.
Run IOS236 installer from Homebrew first to install IOS36 into IOS236, you must do this before you install any other wads. Come back out then run Multi-Mod Manager and select WAD Manager and install all wads in that folder. I've posted this method in many threads on here if you read them.
You can run sysCheck again and post a new sysCheck report afterward installing all the wads.
Keith
2010 Golf GTD (170)
Hi Keith I've got to the last part ..but I am now stuck as to where to install the wads to? (WAD Manager and install all wads in that folder. I've posted this method in many threads on here if you read them.) which source device slot ? do I put them please ...again many thanks for the help
Hi again Keith I think I have sorted out the problem ..I used wad manager but not from mmm I am now doing it from mmm lets see if I got it right this time .. Thanks again
I've now done another sysytem sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.1E (v450)
Hollywood v0x11
Boot2 v3
Found 111 titles.
Found 53 IOS on this console. 1 of them are stub.
IOS4 (rev 3): Stub
IOS9 (rev 1034): No Patches
IOS11 (rev 16174): Trucha Bug NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug NAND Access
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 16174): Trucha Bug NAND Access
IOS52 (rev 16174): Trucha Bug NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug NAND Access
IOS61 (rev 5662): No Patches
IOS62 (rev 6430): No Patches
IOS70 (rev 16174): Trucha Bug NAND Access
IOS80 (rev 16174): Trucha Bug NAND Access
IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
BC v2
MIOS v10
Report generated on 2013/02/03.
I tried the usb loader again re loaded the game but still not seeing it any place ????
Excuse me but your first sysCheck showed 3.2E.
This one is 4.1E why the change?
Generally a sysCheck will add a web link at the bottom so there is less chance of typo's.
That new sysCheck looks pretty good apart from you don't have PriiLoader 0.7 installed to block online and disc updates.
I've tried WAD Manager 1.5 and 1.7 and those have never worked on my 4.3 thats why I always use and recommend MMM. If WAD Manager works for you then ok.
I assume your plugging your drive in the correct USB port the one at the bottom or nearest the edge as the other one won't work for drives. Thats one good thing of WiiFlow if it can't find the drive it shows you a picture where it should be plugged it in.
How is this drive formatted FAT32, NTFS or WBFS? How are you added these games?
Keith
2010 Golf GTD (170)
I noticed it had changed to 4.1E thats happened since I've done what you told me to ....Yes I am plugging it into the correct port on the wii it's formatted to fat32 and in GX loader it sees the game and loads it ..tells me after 12 mins its loaded and I click ok but now on the screen all I see are the 12 channels thats now on, since the work I did ..its a wbfs game ????
