Results 1 to 11 of 11
Hybrid View
    koziolek's Avatar
    Feb 2010
    Under the car
    Default 2001 Audi TT no comunication at all no module respond
    I have a problem with 2001 Audi TT
    Have no communication with moduels
    using launch diagun and vcds 10.6
    radio is disconnected
    I read on another forum that ABS might be the problem
    also disconnected ,
    and still no communication
    please help
    koziolek's Avatar
    Feb 2010
    Under the car
    Still need help
    koziolek's Avatar
    Feb 2010
    Under the car
    I have some update
    when ignition is off I have 5.9v in a pin 7 on diagnostic plug
    when ignition on voltage drops to 0.6v
    Search wire from pin 7 diagnostic socket near socket it connected to star for all ecu's.
    Disconnect wire by wire and try autoscan until you find bad ecu.
    Sorry for my bad english.
    Best Regards
    Darek
    koziolek's Avatar
    Feb 2010
    Under the car
    when I disconnect instrument cluster some module
    come :ABS, Radio, A/C, AirBag, and Headlight ,
    so it looks like instrument cluster has something to do with it
    but what about rest of the modules? why Ecm and central locking control module and some other not responding?
    miha99's Avatar
    Sep 2009
    EU
    Because motor ecm signal goes through instrument cluster.
    koziolek's Avatar
    Feb 2010
    Under the car
    How about central locking module?
    Ashraf6119's Avatar
    Nov 2009
    UK
    have you tried to disconnect the Radio and see if that helps................
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    koziolek's Avatar
    Feb 2010
    Under the car
    Yes I disconect radio no help
    koziolek's Avatar
    Feb 2010
    Under the car
    so no help at all?
