    Member tuning73's Avatar
    italy
    Default PIASINI NOT WORK ERROR " TIME OUT ECU"
    hi all
    big help thanks I bought a new piasini tested on many ECU does not work does not read any ECU MCU identifies but does not read error "time out ECU"
    erases and writes smoothly Reading not work
    help appreciated
    Aug 2010
    Seems you are not meeting the conditions of booting, the hardware recognizes the ecu, the hardware is ok.
    Check your instructions.
    italy
    I checked and tested many ECU the same problem read test ecu 59f.m3 m5 m9 me7.3h4 me 7.9.10
    all the same error "time out ecu"
    followed all the instructions perfectly
    put pin "blu" bot read recognized ECU error immediately
    Aug 2010
    instead of using pin blue, put a 1k resistor to ground on bootpin
    italy
    hi
    I tried with resistance to gnd 1k resistor to ground on boot pin the same immediate error reading no idea ?
    Aug 2010
    Ask your dealer to check it or exchange. Maybe a a faulty K line
