help with epg .only getting next 2 programs up on all channels ?
how do i get 7 day guide? please help
blade 7000 say's 7 day epg?
to get 7 day epg on 28e do the following :-
first scan in transponder (manual scan) 11778V 27500 , and look for the channels like 8010 or portal video 5 that have sky trailers and info
select that channel , then press ok and do an epg update and it will download the 7 day epg for you
then select the guide and alter the epg as you wish using the coloured buttons
always select either one of the channels to do the download when required, as it uses it for its epg information. After you've pressed yellow for the epg update remain on either one of these channels for a minute then you should find a full 7 day epg on most of the channels, the odd one or two channels may not have a full update this is usually the case on the International channel group, but most will.
Hillsborough 15th of April 198996
Ok what ive posted above is what ive been doing the past few months thanks to ramjet who advised me, but the past week these channels have gone blank they may have changed frequency so when i find it i'll post the frequency on here.
EDIT
just leave it on channel 8010 for a min or so to let it download the epg, this channel is showing blank at the moment with 'no audio/ video' message
some of you need to read the happy_highlander thread about it (as it affects the blade and the tm)
http://www.digital-kaos.co.uk/forums...asting-277445/
ramjet to the rescue thankswill try it later
Great box, cable tuner is a godsend for me as I have a big manky tree blocking out 28.2e haha
do you have a cable sub?
thank you works a treat
