Results 1 to 3 of 3
    UK
    Default saab 93 trionic 7 bdm connections
    Was looking for bdm connections for this ecu and the direct connections appear to be similar to edc16, ie
    BDM ECU
    pin1 > pin1
    pin2 > pin2
    pin3 > pin3
    pin4 > pin4
    pin5 > pin5
    pin6 > pin6
    pin7 > pin7
    pin8 > pin8
    pin9 > pin9
    pin10 > pin10
    Can anyone confirm that this is correct pls. And also should the power be applied to the ecu direct or via the bdm module?
    Thanks.
    *This is also posted in ecu section*
    if this post was usefull
    please press
    the thanks button
    May 2011
    Gave you photo on ECU forum
    UK
    Quote Originally Posted by quattrotr View Post
    Thanks, i've also replied there.
    please press
    the thanks button
