hi DK's pleaz i need pin code for radio RCD 310
the dump is attatched
You have been told before .... Full code .. or forget to login ...this is the last time you will be warned ...
kappa1 (12th June, 2015)
@premierd,
if you can....post full code,i can not....@khalilo_de ask only first two digit,not full
have pm!
kappa1 (13th June, 2015)
hmmmmmmm whether I can or cannot post the code as **** all to do with it ... And I cant ... but if you can ... and you know you can ... but insist on the charade of 1xx1 .. the you have the problem mate .. work by PM ..fine no need to post anything then ..
Yes only first two digit.if you know orginal code?if yes?
You can make four digit code.Example 9999.
You can read nec mcu + eeprom?if yes?
You can find code 4 digit!
And you have little money?You can buy rcd310/510 interface.
from eprom is not posible full code,only two digit,rest one by one...
kappa1 (24th June, 2015)
hi code founded 1101 thank u siti for your help
Hi mate's, i tryed to put this dump for my Rcd 310 with the code done but my rcd was only blinking when i swich on!!!!!!!!!
finaly i think this model work only with his original dump .
If you can not fix it, please leave it as it cameIF I HELPED YOU PUSH THANKS AND REP BUTTONS
BOSCH RCD 310 from SEAT
If someone can give me first two digits...
Mackie
" I don't need help but difficulties. The harder the better. I work the best when in trouble."
read MCU i send to forum.
