    Member naveed1111's Avatar
    Sep 2008
    Default Getting Low On Memory
    Hi All.
    i have dm800hd [gemini 5.1] attached with external hard drive and usb stick.
    my problem is after flashing and installing plugins i left with 15 to 16MB of space on internal memory of 60MB,which is good enough to run the box smoothly, but day by day it decrease and when it reaches 1MB or below box starting to crash,and i have to flash it again.
    is there any way to stop this happening.
    Quote Originally Posted by naveed1111 View Post
    Hi All.
    You could have a damaged flash memory (bad sectors).
    There is a option in Dreamup/optiflasher and SUNRAY-Flashup, to clear bad sectors.
    I have given them all a go, sadly it didn't work for me. But you could give it a go.
    I have used them all, as I have a box with similar problems.
    Mine is running with just enough addons that I need, and is left with 1mb, it's very sluggish but doesn't crash or get any worse.
    Mar 2011
    Where are you downloading your EPG to?
    Sep 2008
    Thanks for replying.. i will try Dreamup/optiflasher and SUNRAY-Flashup to see if they work for me.
    As EPG , i used crossepg and it stored in usb.
    all movies,picons into hard drive.
    Stick your picons on the usb also, or the hdd will always be in use. Not ideal mate.
    Sep 2008
    Ok..thanks for mentioning about picons
    , didn't realise before
