could anyone watch the files, is there something wrong or not?
DK is the best !!
Department of factory errors.
Hallo maybe ther anything wrong but I am not sure no faults car have power .
anyone can help!
DK is the best !!
ECUSAFE don't work for this car.
Ok but if anyone can completely remove the dpf of the car ,I do not see other problem as the fuel consumption, it seems more that it must be.
DK is the best !!
I did one E60 530D with EcuSafe and works perfect
ecusafe doesn't work properly in 95% of cars listed. stop using that software if you don't understand what it does.
Ok I understood that most likely is problem in ecusafe that the fuel consumption is higher that should be .Have anyone a good solution for me.
Please.
DK is the best !!
I would grateful it if someone manually can take off dpf of my car.
Thank you in advance
DK is the best !!
For dpf off on BMW with DDE7 (edc16), the absolute best solution are to use the BMW original software suited for engines without dpf. It exist software from BMW for certain markets for EU3 emissions, this software are without dpf. With good knowledge to BMW coding and programming someone can flash the ecu with the correct software by themselves by use of Winkfp.
or just switch it off correctly in the software )
I`ve done couple of this cars and best way to do that is remove dpf from software using ecusafe or changing maps in winols and after that clean dpf with pressure washer and hydrochloric acid 33% (you can buy this from guys who has car wash)
Have you tried this yourself? if not please don't recommend to others.
1.ECUSAFE DON'T WORK !!!
2.Using HCl solution on DPF will reduce it's properties and problem will be back in 10k km.
Need make in winols. I can dfp - egr off correkt.
