did you test and you can not? I made a file for you fap off egr off hello
pass pm
Hi mate,
I need from worked, 100% tested manually solution for DPF OFF in Opel Zafira 1.9 CDTI without erasing all DTC and with switch off differential and temperature sensors and the errors for them. I can pay for this solution, PM for price. Thanks in advance.
Best regards.
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
pass pm
Alexaay (23rd August, 2019)
Any help for EDC16C39 and this file ... ? I need only from DPF OFF.
Best regards.
Where are all tuning masters ? Someone can help me or this is not possible ?
Best regards.
This file fap off with greetings
Soundnavigator I can help you if this file would be bad...
Magicmotorsport Flex Full, Magpro2, Swiftec, Winols, full ETL, Carprog and others....
I also have problems with dpf off for Zafira B Z19dt.
Read it with mpps and modify with ecusafe. seems like it doesnt work becouse glow plug light still flashing and particular filter saturation in MVB shows 200%. maybe someone can help me...
.ori file attached
Nio (14th April, 2013)
Yes,i missed that... it now works for me, so big thanks.
Hi i have a zafira z19dt with a edc16c39 ecu id 55570807 MJ i trued to remove the filter and egr with ecu safe 1.9 and 2 the filter has been removed from the exhaust but the car has a strong exhaust fumes smell i have blocked the egr pipe with a gasket with no hole to blank the egr. i have posted the original files would someone please remove the egr and pdf from this ecu, thank you.
Seems like you need many files! How job is going?
Sent from my PAP4300 DUO using Tapatalk 2
Galletto 2012 v54 full with JTAG and Mini available
Big Stars never dies:
Colin McRae (1968 ***8211; 2007)
Richard Burns (1971 ***8211; 2005)
Georg Plasa (1960 - 2011
Babos (24th April, 2013)
Can you give me clue for remove FAP manually?
Bosch Hardware Number: 1037383479
Bosch Software Number: 0281014024
Opel Software Number: 5520562
Engine Type: Z19DTL
