Results 1 to 8 of 8
    DK Veteran ghostridersa's Avatar
    Nov 2011
    Default Renault Clip v117 activation code help
    Good day members of DK
    Can any members maybe help me with activation code for Renault Clip s/n: J472Y2Y.
    I also have 6 blocks showing which I dont know what they are for read as follows:
    A 1067F7
    B 1111B7
    C 712254
    D 5205B0
    E 002762
    F 000993
    I will be most grateful if any members can help me with the activation code for the above serial number.
    Many thanks in advance.
    May 2012
    as far as i know renault clip update v120, where did you buy it? you can get activetion code with seller.
    Jan 2010
    Elsewhere
    V120 found on the net, cracked, no need to register, works perfect.
    Made myself yesterday new install of V120
    drakov's Avatar
    Aug 2008
    Quote Originally Posted by ghostridersa View Post
    A 1067F7
    B 1111B7
    C 712254
    D 5205B0
    E 002762
    F 000993
    111D0C 222803 000F22 7779F7 111574 33234F
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Member SANTI-MECCANICA's Avatar
    May 2009
    Quote Originally Posted by alfabit View Post
    I can indicate the installation steps. I have problems if I change the file installation rsrwin, it stops working and if not I have no code change.
    Sorry for my English.
    Jan 2010
    Elsewhere
    Must follow step - by - step the procedure indicated there, and it will work .
    Dec 2010
    balkan
    Hi all,
    I also need to register Renault Clip, if someone can help, please,
    serial number L3LGNK4
    A 10118B
    B 11117F
    C 71443D
    D S1185F
    E 033387
    F 000362
    Thanks in advance.
    Jul 2010
    Some systems do not accept registration with pach crack,
    In this case put back original RSR and see if the software starts.
    If it's ok, change the year in the date of computer(ex.2013)
    Start clip from shortcut
    It will announce that you did not update 365 days
    Now put the current date.
    Open the original file but do not activate the RSR.
    and now normaly activation
    Backup the RSRWin.exe from C:\CLIP_X91\Lib\Application\
    then copy crack\RSRWin.exe to C:\CLIP_X91\Lib\Application\
    2. Then run your CLiP, choose "Register me now" and in the next
    window select "NO"!
    3. Use this Key for Registration: 333DEF-111DEF-111DEF-222DEF-221DEF-000DEF
    It will working until 31/12/2020
    4, copy the backup RSRWin.exe to C:\CLIP_X91\Lib\Application\
    Regards,
    Aniic
