ok mate almost all of the newer games especially motion plus ones need to have the alt.dol used before they will work on neogamma, even then they may not work there is still no alt dol for spiderman and batman as there is almost nobody working on them cause nobody uses disc anymore. Here's an option though but don't know if it will work...Try Usb loader gx 3.0 it will now launch without an hdd plugged in you just have to press "B" when the waiting for usb device countdown is on. Here is the All in one package Digital Kaos - Downloads - USBLoader GX 3.0 All in one package all you need from this package is the UNEO Forwarder wad from the wads folder (just copy it into your wads folder and install with mmm into ios 236 the copy the gx folder from the apps folder into the apps folder on your sd, launch gx and in the top right you will see adisc click that and you will be able to play games from disc using all the features of gx i.e changing cios to load games like cod, monster hunter tri and the likes but it also gives the option of blocking ios reload as default and sources alt.dols from the net so you don't have to go looking for them...Good luck and let us know how you get on, if this works properly it is going to leave neogamma dead in the water
