check with supplier he does hd,and not just sd.
Its my own card and they work in sky box
Mickr
I have same problem.
I use CCCam and Sky HD,,,, you need to check that your boxkey is set correct. In the ET9200 you have 2 card readers and need to set the boxkey and frequency correct for both readers. CCcam will read the SD chanels without the boxkey, but not the HD. You will find that cccam wont clear Pick TV and Boxnation.
BOXKEY:/dev/sci0 01 01 01 01 (sub for your own)
BOXKEY:/dev/sci1 01 01 01 01 (sub for your own)
SMARTCARD CLOCK FREQUENCY: /dev/sci0 3570000
SMARTCARD CLOCK FREQUENCY: /dev/sci1 3570000
Edit --- I think it's okay to post this, but if not please delete.....
Thanks for that, tryed in other slot and it works. So I have modifed config file as above and now works in both. Have noticed some speech out of sync on hd channels anything I can do about this
With thanks
Mickr
Yes, press the audio button on the remote then audio sync. You can then move it forward or delay it further.
also when you press the audio button, check is not on NAR
