Results 1 to 5 of 5
    Apr 2011
    France
    Default Problem with immo Zafira Y20DTL
    Hello all
    I have a problem with a Zafira Y20DTH estate
    the engine was changed, the pump (EDC15M) the numbers do not match wine to the car.
    I have the original code of my car not the engine
    my question:
    Possible to have the immo code from the VIN?
    W0L0TGF752H024604
    Thank you is what brings me to help
    Apr 2011
    France
    Hello
    I finally found the ECU
    Here is the 24C04 can immo code given me?
    thank you very much
    Apr 2011
    France
    problem solved
    thank you
    DK Veteran rachmach's Avatar
    Jan 2011
    Workshop
    how do you solved your problem i have the same
    Apr 2011
    France
    What is the problem with your car
    I've reprogrammed the original code
    thank you
