Results 1 to 4 of 4
    Jun 2012
    Default motorised channel list openbox s11hd
    Hi anyone got a motorised channel list i can load on this receiver please
    Regards
    appymcfc
    DK Veteran nibblitz's Avatar
    May 2010
    You'll be best to scan and sort your own, as only you know what satellites you actually want.. Remember, you can only store 5000 channels, so work out what satellites you personally want, scan one sat then sort and delete channels you dont want, then go on and scan the next satellite.. If you go off and scan half a dozen satellites all in one go you'll quickly run out of channel space..
    Jun 2012
    thanks did that already and ran out of space but when i scanned i did not pick up all the channels on each sat that i ought to have i tried blind and accurate scan
    i will delete channels and compile the lists myself thx for the reply
    DK Veteran darcu5's Avatar
    Jun 2011
    Bolton, Lancs.
    For the missing channels you will have to check the transponders for the the missing channels on kingofsat.net then manually add the transponder into the box and scan it...
    If it isn't broke, don't try fixin it..!!!
