Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Member nikinik's Avatar
    Haskovo,Bulgaria
    Quote Originally Posted by Artilect View Post
    If you need just change the SN you can use this Tool. It is soft for changing VCI SN via USB. No need to desolder, flash,...
    And dont forget to thank
    BR
    MILLION THANKS!!! JUST FOR COLLEGES THAT DONT KNOW ,WHEN
    WANT TO CHANGE SERIAL DEVICE MUST BE NOT ONLY IN USB ,BUT OBD PLUG ALSO PLUGED IN WITH IGNITION ON.
  2. #17
    DK Veteran Artilect's Avatar
    EU
    Yes the VCI have to be connected to OBD, to get power supply.
    BR
  3. #18
    Top Poster ioanrokos's Avatar
    Thessaloniki Greece
    Hi all of you! Any SW for changing serial in new CDP+ of Autocom VCI?
  4. #19
    Dec 2015
    I am looking for the same thing. Is it still possible to change to the gold autocom?
    Thk. I am google-ing around but very few hits.
    BR
    reyx
  5. #20
    tehnosoftex's Avatar
    Romania
    No way to change serial in vci+ without changing the mcu.
  6. #21
    Jun 2009
    QUOTE=tehnosoftex;2673552]No way to change serial in vci+ without changing the mcu.[/QUOTE]
    It's not true,Mr.Fantomel from other forum has solution,thanks him.CDP+ OTP AREA READ WITH ST-LINK.jpg CDP+ J400 TO STLINK PINOUT.JPG
  7. The Following User Says Thank You to mdanilo For This Useful Post:
  8. #22
    Aug 2019
    Can i change my gold autocom vci (30250) to serial 100251 si it will work with the new 2016 program?
  9. #23
    Feb 2018
    no need to change, just install autocom 2016, at the beginning of installation just select 30250, and it will work for you, i also use gold autocom with 2016 software
  10. The Following User Says Thank You to zoki21 For This Useful Post:
    rankan (6th March, 2021)
  11. #24
    Dec 2014
    PL
    I have something like that. Probably to change SN. Unfortunately I didn't try.
  12. The Following 5 Users Say Thank You to Mario6 For This Useful Post:
    a17h641a (27th February, 2023), akinow (3rd July, 2021), PaoloDigital (15th January, 2022), rankan (6th March, 2021), Rasmus (12th July, 2023)
  13. #25
    electronistul21's Avatar
    Nov 2011
    galati,romania
    I try this ,and work good and very fast ,without soldering nothing.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  14. The Following 2 Users Say Thank You to electronistul21 For This Useful Post:
    Autodoc14 (3rd December, 2021), rankan (6th March, 2021)
  15. #26
    Sep 2019
    Thanks you been searching ages!
  16. #27
    Jun 2016
    hello, were you able to change serial? I have to change serial from 5 to 6 numbers
  17. #28
    Aug 2020
    Quote Originally Posted by mejinn View Post
    You need to buy a better vci.
    You can not change from 5 digit to 6 digit serial.
    You can keep searching if you like but it is not going to happen.
    Surely you can at least afford to buy a good tool when you get the software for nothing.
    Your 2nd post in the whole 5 years that you are a member here............ wow.
    HaynesPro online + 2022.02a version available, message for where to get it!
  18. #29
    Jun 2019
    try to change the SN.txt file in autocom files
