What errors you have?
"No loading cars list, and shuting down" or "No VCI found" ??
For both errors use search on forum to found the solution.
no vci found
nothing can help`??
Desolder Tiny45 and program it in external programmer.
I've programmed mine autocom with wellon and it works fine. You just need to unsecure eeprom first and secure after programming.
hi you have dump good to autocom?
sure.
Here is with serial 39071 but there is no problem to change it in any hex editor.
Pass on PM.
If you need just change the SN you can use this Tool. It is soft for changing VCI SN via USB. No need to desolder, flash,...
And dont forget to thank
BR
adam1w (3rd October, 2018), aigarsss (27th September, 2022), aitistu (24th December, 2018), anrolo (8th May, 2017), aqeel1963 (16th February, 2019), BolleGTR (30th May, 2020), Carver (23rd January, 2022), Chokito5 (25th June, 2013), crush231 (23rd November, 2020), dimitrisyn (24th June, 2017), draganbl84 (4th August, 2018), dragosvlad97 (24th December, 2018), endjov (23rd February, 2018), fadedtracer (18th April, 2016), frog139 (21st November, 2018), Ghost899 (26th February, 2020), HackBv (13th April, 2023), Hugolainz (17th June, 2019), Jakob201082 (10th January, 2018), josmatos (20th May, 2019), Kaiten92 (22nd August, 2020), klauskj (15th September, 2020), korov2000 (20th April, 2021), leopardd (25th January, 2018), Lojza123 (8th May, 2021), lordmmx (18th January, 2022), marsete (11th July, 2018), Martin80 (26th March, 2017), Michal Benni (Yesterday), parrot1964 (8th June, 2020), rafalgt (13th May, 2019), rankan (6th March, 2021), sato-bmw (29th May, 2017), Tabare36 (10th September, 2013), Tawaho (2nd November, 2023), typer12 (21st June, 2018), vagdiag0com (24th September, 2021), vitorponte (18th February, 2023), yasser (20th March, 2021)
If you need activation for Autocom 2011.3 I can also help you, just post jour XML files.
As I know there should be no limit in number of flashes. It is just soft for changing the VCI SN. I have use it alot of times to change the Autocom VCI, I asume that is also usable at Delphi VCI, it is same hardvare, but I didnt have chanse to try.
BR
Artilect, thanks for sharing! I'm a newbie in this forum and really appreciate your support
The solution is (delete the software then install and active again):
1- Uninstall the software
2- Delete the license (search folder name autocom in windows. and delete all folders)
3- Setup software. And make activation
The steps for not detect VCI:
1. Disconnect from internet
2. Delete folder with all files in it: "c:\Documents and Settings\USER\Application Data\Autocom
3. Delete folder with all files in it: "c:\Documents and Settings\All Users\Application Data\Autocom
4. Start Main.exe, reactivate software and you're done!
5. Most important, stay off line from the internet.
