Results 1 to 12 of 12
    Sep 2010
    Default EDC16C34 P307
    Solved
    DK Veteran 70max's Avatar
    May 2012
    Default Egr
    Hi friend,
    Try this would work.
    Warning codes injectors when the ECU programs
    greetings
    Sep 2010
    OK, thanks,
    did you test it this type of modification in another file/car? I think that must be one byte like a switch which tells EGR yes or no.
    May 2012
    Default Egr
    used in another car and it works,
    There are two other controls in the map view this file in the first closed only two.
    greetings
    Quote Originally Posted by vopi View Post
    I need to make EGRoff in this ECU, please help me with finding of EGRoff switch in EDC16C34 Peugeot 307 1.6Hdi. I have damos file but not complete and I can?t find this switch.
    Look to the attached file and please help me with this switch.
    thanks a lot.
    not good dpf/on egr/off
    Sep 2010
    OK, I thought about it if it is a problem when I remove EGR and keep DPF filter.
    Is it fatal problem for DPF If I switch off EGR?
    temperature of exhaust gas egr off more .. you can do egr off and dpf on but you should not .
    Mar 2009
    Europe
    Please for EGR of from my file..
    I try with volta not work..have errors:
    P1162 - EGR solenoid valve circuit, component blocked
    - Permanent
    P0489 - Too much EGR, valve too open in relation to the reference value
    - Permanent
    May 2012
    Quote Originally Posted by maki View Post
    - Permanent
    - Permanent
    EGR off
    Pass PM
    regards Max
    Default 307 egr off
    help edc16c34 peugeot 307 egr off
    Mar 2009
    Europe
    I tested this dump and have same error P1162 and P0489 ???
    Jul 2012
    Default egr off
    Quote Originally Posted by dorinprundus View Post
    if you want help for egr off you need to enter your original file
