Results 1 to 5 of 5
    Jul 2012
    Default Help with Reciever.
    Hi guys,
    I'm trying to add t.v pack!
    This is on a protek 9700HD!
    I have writen this in sever 1.
    This is what i see, and what i have writen what the provider gave me! (but of course i'll leave the details out below )
    server name ?????
    sever ip DNS on 0.0.0.0 (is this meant to be 0.0.0.0)
    Port ????
    User ID ????
    Password ????
    DES Key 01 01 03 04 05 06 07 08 09 10 11 12 13 14
    EMM Disabled
    Protocol NewCamd
    I turn the box off then back on, but channels are scrambled.
    The server 1 has a yellow light, this should be green!
    It then says connecting to (numbers)
    Unable to connect.
    Resolving (provider name)
    Resolving ip= (numbers)
    Keeps saying same thing!
    Not sure if there something else i'm meant to be doing!
    The yellow says copy from other server. not sure what this does.
    What could be the problem? the internet is pluged in.
    network setting mode is set to DHPC
    Thanks alot
    Regards
    Mark.
    Nov 2008
    the server ip dns is the hostname you were given , like hostname.dyndns.org
    the port is the port you were given, like say 12000
    the User ID name and password are self explanatory
    the deskey is correct for newcamd
    Jul 2012
    Quote Originally Posted by ramjet View Post
    I think you missunderstood my question
    I know where to put the info
    But it wont connect.
    I just didn't want to add the info on here
    Unable to connect.
    Anyone know if there is anything else i have to do to get it to work?
    Cheers.
    Nov 2008
    no I didnt misunderstand
    you said you had put in 0.0.0.0
    ( sever ip DNS on 0.0.0.0 (is this meant to be 0.0.0.0 )
    my point was that you should have put in the server hostname and not 0.0.0.0
    Jul 2012
    0.0.0.0 comes up on it's own. i can only change it to number.
    I have put server host name in the server name, there is no where else to put this..
    Sorry i'm put confussed by your replys
    Cheers.
