Results 1 to 15 of 16
    Jul 2012
    Default IR remote externer for Skybox S12
    Hi there,
    I'm looking for a ir extender compatible with the ir jack on the S12? I've hidden the box behind the tv, and would prefer not to have to get up and point the remote behind the tv! Something like the sky magic eye but with a 3.5mm jack instead if an rf connection.
    Thanks in advance!
    Sep 2008
    can you move position of box?if so try the cheap free fix first,use tinfoil to reflect signal from remote to allow box to receive signal.worth a try first
    Jul 2012
    Quote Originally Posted by cactikid View Post
    Thanks for the quick reply. I'd prefer a nice looking installation- does a device like that even exist for the skybox?
    Sep 2008
    there are a number of different ones out there,some using rf,does your box have that ir socket?
    Jul 2012
    Yes it does, a 3.5mm jack (im presuming that is what it is for)
    Sep 2008
    think triax have something not found it yet ,i got their new saorview combo and noticed it had an ir output jack also.
    Sep 2008
    only found this mainly for use in a second room with another tv
    Triax Trilink Kit - Modulator and Sky Eye Power
    need to double check if that is correct jack,like headphones were mono then stereo and jack changed.
    http://www.ebay.co.uk/itm/3M-IR-EMIT...item4845dfd474
    Jul 2012
    3M IR EMITTER 3.5MM MONO PLUG - INFRARED SYSTEM REMOTE CONTROL EXTENDER | eBay
    Thanks for that, that second option looks good, might chance one.
    Sep 2008
    ask the supplier a question and report back to let others know cheers.
    Jul 2012
    I've spent all day trying to find something, but to no avail, unless I want to fork out for a repeater system. Which I don't. Has anyone plugged anything into the IR port on the S12?
    Sep 2008
    any image i google does not show an ir port,think you need to recheck what box and bung up a photo.
    DK Veteran nibblitz's Avatar
    It will need an IR receiver, not an IR emitter.. I wouldnt advise you buy and plug any make of 3.5mm IR reciever in there, its almost certainly a proprietary wired socket.. If you plug a mono or even a stereo plug in there the wiring will be wrong and you might short circuit something internally..
    If its any help, I have a Skybox M3 that came with an IR reciever to plug into the 3.5mm IR socket.. The 3.5mm plug has 4 cores, so thats 2 more than on a mono plug, and one more than on a standard stereo 3.5mm plug.. I assume it might be the same for the S12, but then it might not..
    I think your best option is maybe send off an email to an Openbox/Skybox manufacturer in China, see if you cant order one..
    Cactikid, the 3.5mm IR port is on the side
  13. #13
    Jul 2012
    thanks for that guys, I've emailed the manufacturer and I'll report back what he says.
    btw, does your ir receiver have any serial number etc. I could google?
  14. #14
    Nope sorry, there's no identification markings on it at all.. Good luck with getting one from China..
  15. #15
    Jul 2012
    Thanks- i wonder would anyone have a spare one I could buy? Where would i look?
