and?
and?
the same version i've installed but not the one you've posted, it should be the same right?
You think that i should think that i should only post if i have installed your version?
You think i should think that the version i installed is determined by the mother fvucker thats decided to change it from the original discs.
You think that i should think that a simple question about expiry should not be asked if it has not come from the original poster, even if it is the same version?
Now you understand why i am cynical
Regards
Impactops
Yes! Or warn that you have a different version.
Original disc? This does not exist on the web, only modified and customized versions.
All my versions and my updates have a way to stop it from expiring. Only my last update not. Must edit file EtStart.ini
No comments, if you say it....
I'm Portuguese, so i apologize for my very bad English.
If your expecting members to distiguish the difference between versions published from Dickhead A, Dickhead B & Dickhead C as compared to the version of the software, then you are on the wrong forum, con men are across the road
Why??? Because it does not come up on google search??? therefore it does not exist???
I think you're a little late, the JC boys thought the same thing
For your updates it's this, for someone else's update it's that.
http://www.digital-kaos.co.uk/forums...ssword-348431/
At the end of the day conmen can only produce regurgitating solutions, nothing new will come from them
Regards
Impactops
problem is a serial key!!!!!...
HI ALL
THANKS ADVANCED
Hello, Anyone by any chance could make Etka 7.4 work on Windows 8.1 x64 ?
Hello. Is there any update for etka 7.3 plus 2013?
[Quote = Rui Aguiar; 2047494] A?adido Nuevos Precios y Actualizaciones Hasta 08 hasta 2013 : AU-973 a 976, SE-499 a 502, SK-505-508, VW-973-976 [/ quote]
Lexio and Ecuaskoda,could you both please go here to introduce yourselves please ? : Introduce Yourself
And in English too !!
same prioblem with aa.. hope it will help thanks guys
thank you man
thank you ..!
I am trying to crack ETKA , anyone has interests? I want to get all informations from etka
please i download etka ETKA 7.X PLUS 09-2013 i don know inastalatio key.help me please i dont know what to do? my email iz *********
