Page 3 of 18 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 265
  1. #31
    Member moza's Avatar
    thanks pass please.and after try this ....
  2. #32
    Member Mjheavy's Avatar
    Jan 2012
    Boston, USA
    I talked with the guy from specdiag.com, He claims that he can licence 2012B ET. Has anyone tried any of his 2012 licence's yet?
  3. #33
    Nov 2010
    Quote Originally Posted by Mjheavy View Post
    i have not. but he is trustworthy.
  4. #34
    Oct 2010
    thanks pass pliz
  5. #35
    May 2012
    Quote Originally Posted by niltonj59 View Post
    Check pm............
    Amigo me puedes ayudar con el password?
    gracias
  6. #36
    Jan 2012
    Password please, Thanks in advance.
  7. #37
    DK Veteran Gilang's Avatar
    Aug 2012
    Southern Kalimantan-Indonesian
    This file exe no password https://hotfile.com/dl/161457517/c52..._v1.0.exe.html
    Then this file comet application
    If it my post it's helpful, please get push "THANK and REPUTATION"
  8. The Following 2 Users Say Thank You to Gilang For This Useful Post:
    mang5087 (9th August, 2013), meporter (7th November, 2013)
  9. #38
    Jan 2011
    OK, what am I doing wrong?
    I installed 2012b. I renamed the original comet.exe file then copied that 2011c comet file to \common files\offboard information products\2012b\comet but 2012b fails to start. It gets a fail to load comet error.
    I think I may have to install 2011c with that comet file then upgrade to 2012b but I don't have a copy of 2011c to try it
  10. #39
    Member andreytora's Avatar
    Good day!
    Please, can I have pass?
    Thanks!
    Who not with us - that against us, and no hatred - a work only!
  11. #40
    Member lkrasovsky's Avatar
    Ukraine
    Post Hello Gilang
    Please tell us what must we do with the comet.exe file ?
    Por favor dinos Que hay que hacer con el archivo comet.exe ?
    Is that a cracked file ? I tried to replace it but I got an error trying to run ET2012 and then it close itself.
    Ese es el parche ? Trat? de reemplazar el archivo original pero me da un error cuando trato de abrir el ET2012 y se cierra.
  12. #41
    Apr 2011
    I looked everywhere tried the comet fix and entered my ip address etc and still got error codes.
    I finally folded and paid the $250 to get it activated.
  13. #42
    Hi Gilang
    You have come this Far...could you help us out with some instructions....you have never failed the Forum before...you have allways offered a helping hand....could you give us a little push with this Cat et 2012b + Comet File? thanx
    Thanx for all the great work....
  14. #43
    Jul 2012
    please...installation instruction for comet...thanks
  15. #44
    Jan 2012
    Boston, USA
    Any update on what to do with the Comet file??
  16. #45
    Apr 2011
    I got mine activated for $250 dollars but it was not by specdiag and it works fine
