Results 1 to 4 of 4
    Top Poster Ev0151's Avatar
    Jan 2009
    Default Eurovox recording issues
    I know nothing in life is easy ..
    Thats how i knew when i bought my Eurovox EX5100 it was never gonna be easy.
    Anyway .. i seem to be having delay issues when pausing live TV - seems theres a 30 second delay once you hit pause.
    Is this a hardware problem or something that can be fixed with an firmware update ?
    Jan 2009
    Sorry that's how it works. Unlike SLY+ that pauses in real time the Eurovox actually records the "delay" to hard disk, so it needs to set it up. If you look in the recorded area after you watched the paused section you will see the recording
    hi
    you seem to be a lot more experienced than me
    I just got my hard drive a couple of days ago
    I've found I can only use PVR on the station I am watching or if recording I cannot change to another channel
    Is this normal ?
    ta
    plr
    badapple's Avatar
    Dec 2008
    REQUEST
    Quote Originally Posted by plrandall View Post
    hi
    Is this normal ?
    ta
    plr
    Hi m8, this is normal as this box only has one tuner so you are limited to what you can watch and record at the same time.
    The only way its possible if both the channel(watch and record) are on the same transponder.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
