Results 1 to 15 of 16
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    Default mb w210 ezs hash error
    today have got one w210 in workshop with all key stopped working, have readed the upper motorola for try to calculate keys with skc but all key tracks have hash errors,
    for the expert here one question can you repair only hash error in upper motorola so i can use skc to calculate keys or you need both motorolas readed
    i will upload now the upper cpu bin file if needed i can read the other cpu too...
    and also with repair hash error dump and generating keys with skc do i must make esl and ecu virign also or the key will start right away?
    thanks for your help
    smayer's Avatar
    Jan 2012
    I Can repair the hash errors but if you don't repair in both MCU maybe EZS don't work. Read the MCU inside and post.
    exxl's Avatar
    Jun 2009
    in 30 minutes i post it if you have time i would like to finish it till tomorrow the job thanks
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by exxl View Post
    30 minutes to remove and read the MCU? you need work faster (just kidding)
    exxl's Avatar
    Jun 2009
    have readed the bottom cpu 1h52a, but looking at the dump of 1h52a all tracks dont have hash errors seems everything ok with it
    please take a look at both upper 0d69j and bottom 1h52a
    ps: have needed only 22 minutes
    smayer's Avatar
    Jan 2012
    I need more then 22 minutes to repair hash, the program i use is tooo slowly...
    smayer's Avatar
    Jan 2012
    your dump repaired
    exxl's Avatar
    Jun 2009
    thanks again, will check it them tomorrow on car
    and give feedback
    regards
    smayer's Avatar
    Jan 2012
    You can test ezs in bench. Dont need make esl or ecu virgin.
    bram380's Avatar
    Indonesia +628153111774
    you can clone
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by bram380 View Post
    you can copy some data cpu2 to cpu1
    what i have done?
    bram380's Avatar
    Did you solve the problem?
    (Ser? que o problema foi conclu?da?)
  13. #13
    smayer's Avatar
    Jan 2012
    Do not have faith in my work?
  14. #14
    bram380's Avatar
    Misunderstanding of the sentence mate
    Smayer can do it right and proper.
  15. #15
    smayer's Avatar
    Jan 2012
    Just kidding mate, and if I can do I'm sure you can do better, I'm just a beginner.
    (ser? que o problema foi resolvido?) Google translator fail sometimes
