your zip file does not open!
Hi Chaps,
i have a what is a so called tuned file here from an EDC16C9 1.9 tdi 150 bhp Saab 9-3 but before i upload it to the ECU could the people with the knowledge please have a look at it and tell me if its ok to flash the ECU with it? Also any feed back on the Tuned state of the file would be appreciated.
Chrisogor
ok I can open your files now ...
your edit is not very good! you ask drivers whisch 48,torque limit 41 ..
fap on / egr on
injection time and just got an early increase
to this address and the next 0ccb42 there are values ***8203;***8203;in the negative
Many maps are missing have not made a good change ..
the cks family is ok 60
Perhaps the negative values ***8203;***8203;are not good in this file hello
ries to write the original file to see if your car part
Perhaps you've misspelled the edited file ..
your edit is not very good there are negative values ***8203;***8203;in the map but it is strange that the
Mod file is shite
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
Pay a professional if you want a good file, people spend 100s of hours learning the trade to produce good work. If people think it is possible to cut corners, then this is the result I'm afraid.
