Results 1 to 5 of 5
    mobileworks's Avatar
    Buenos Aires
    Default retriction disable in edc16cp34
    i have mounted in other car ,without electronics , one motor audi v6 tdi 3.0l denom: asb
    the problem is retricted without other devices orig; abs airbag ,dash an gear electronic instaled
    ,car run but with lees power ,do any body have ,how make desactive rectriction and make more power
    (rpm limited to 2500rpm..
    thanks in advance juan
    UK
    you need to do a diagnostics to find fault code why engine is running in limp mode......start from there
    Spain
    Hi M8,
    You need to conect/close, clutch pedal swich wires!
    Regards.
    Buenos Aires
    yes , i try, but the problem, is faulty in signal from abs ( velocity signal not present) i need or simulate via can or disactive in map... thanksss for your interest in my problem..
    Spain
    Hi M8,
    I?m not sure if you need speed signal from ABS, but surely you may need to close CAN wires with an 120 Ohm resistance (end of line).
    If not, the solutions are recode or reflash ecu.
    Regards.
