Results 1 to 7 of 7
    May 2012
    Under the cosh
    Default Multi-epg not working
    Lo there,
    Noticed strange thing with the EPG last night
    On BH 1.7.6 and pressing the up or down arrow to bring up the channel list followed by pressing "3" used to give me a multi epg with the graphical layout. Now pressing "3" gives me the same as "2" - single EPG listing.
    Any ideas? Plugin conflicts?? if so - which?
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Quote Originally Posted by meggiedude View Post
    Lo there,
    download multi quick button plugin and assign your own, i use B.H. 1.7.6 on my uno with crossepg/coolmans without any issues.regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
    digicon's Avatar
    As mdt has rightly pointed out you would be better using Coolmans guide as your frontend program for crossepg its a lot nicer looking and can be customised, Multiquick button will allow you to assign any button on your remote to any command in the database.
    Coolmans and Multiquickbutton can both be had from the blackhole feeds.
    Apr 2012
    same here, having exactly the same problem, however when i press 2 or 3 to access single or multi epg, the channel selection changes to the corresponding channel on the bouquet ie 3 changes to channel 301-sky premiere
    digicon's Avatar
    Quote Originally Posted by Bumsrus View Post
    Never come across this before although i have always installed multiquickbutton and coolmans guide as i think the frontend on the BH one is a little poor and needs some work.
    It could also be a plugin conflict
    May 2012
    Under the cosh
    In the end mate I installed the coolmans guide as advised and am using that. The interface is far better than the stock BH one.
    I also tried the multiquickbutton as well, but found that it over-rides some of the options I wanted with the coloured buttons. If you want to frig with it for a while I'm sure you can get it to do what you want, but its not really worth the effort.
    With the coolmans guide setup addon option which gets loaded into the addon menu you can configure the red button to have the graphical bar chart EPG interface with TV pic shown top left.
    You don't need the multiquickbutton loaded for this to work. All the rest of your buttons can stay as is.
    I've forgotten about my issue with the 2 and 3 buttons now as I don't use them for EPG.
    This digicon is right though, the 1.7.6 interface needs some work and its still buggy. I also agree that there may be issues with addon conflicts, as on occasion I am seeing differences depending what is loaded.
    I am also seeing the limtations of this box when it comes to addons in that I am getting occasional crashes which give a green screen and an out of memory error.
    So i've removed all addons that are superfluous and only have the ones I absolutely need loaded.
    These are 1channel, coolmans and TSPanel. Thats pretty much it.
    May 2012
    Under the cosh
    As an aside, and its off-topic really, I am also getting green screen of death crashes consistantly when I check device info in the TSPanel addon. Don't know if this is 1.7.6 issue, out-of-memory or something else.
    Probably open a new topic on this one.
