Results 1 to 3 of 3
    Dec 2009
    Default Usb timeshift, cant get the USB working
    Hi all, I have a DM500HD Clone, and got the PP-Neverland up and running good, but I can not get the USB working, can't find the USB in the media selection. It do not even light up when I put it in.
    Edit: Got the USB stick working, mounted and initiated but no time shift working.
    Any ideas anyone?
    Regards
    Appen
    Sep 2011
    make sure you have a good usb stick as i had similar problems. I then got a external drive and bingo timeshift recording. Dont think some of usb pens can handle it .
    Oct 2012
    Default Same problem
    I am having the same problem. My usb works fine, it stores the epg and I can see it in filelist but the time shift doesn't seem to work. Can somebody confirm that the timeshift should work with the usb pend drive or is it mandatory to use a hard disk?
