Results 1 to 8 of 8
    Default Golf V 1.9 105hp speed limiter
    Hi, need to increase the speed limit is in the flash or in EEPROM? Thanks
    Nov 2011
    eeprom, but there is a switch in the flash to switch to backup value in flash.
    I don?t know the switch, but i can change eeprom speedlimiter.
    So, please read eeprom and post it.
    br
    Gerhard
    portugal
    Default Jetta 1.9 tdi 105
    Good night, someone help me remove the speed limiter, thank you.
    monitel_service's Avatar
    ROMANIA
    your file with no speed limit
    Jul 2012
    BG
    bad service monitel_service... sapopt provide to you 2MB file size and you give to him just 1 MB file.
    you are not so proffesional, but from file name for sure you use ECM Titanium (maybe cracked version)
    ROMANIA
    if you say , but check before you post
    Jul 2012
    BG
    monitel now you change files and told this like a gipsy. next time recognize your fault !
    ROMANIA
    is a same file
